09-03-2016 | #11 | |
Re: 90 degree adaptor for Fuel Pressure Test Hose
But I believe that ain't correct for the external thread of the fuel pressure Schrader. I looked further and I do think it's very likely 4AN - if I were looking to fabricate a 90° adapter I'd take the cap and check the cap against a 4AN first. That thread would make it 7/16-20 and an OTC 7430 adapter matches that for thread dimensions. -32 TPI is considered I guess "small Schrader" in fuel pressure language. This adapter is part of the higher $$ Actron pressure kit https://actron.com/content/right-ang...hrader-adapter All of the "higher end" gauge packages will likely use what the OP has mentioned finding. I used a Cornwell Tool kit to sort "nomenclature" http://www.cornwelltools.com/webcat/...aster-Kit.html Refrigerant/AC is 7/16-20 I believe. Last edited by WVZR-1; 09-03-2016 at 02:41 AM. |
09-04-2016 | #12 |
The routing I use works ok for a straight fitting, see this pic.
Roger 1990 ZR-1 #2699 Black on Black 15,000 miles Full-time secondaries, 4.10 gears, C-beam plates, ported top end |
09-06-2016 | #13 |
A straight fitting is all I use too, FWIW. I hadn't thought of running the hose under the alternator bracket tho.
09-06-2016 | #14 |
Where did you get the extension hose for the FP Gauge?
Looking for a ZR-1 1985 Yamaha RZ350-NOT STOCK 1971 Yamaha AT1-Middle of a restoration |
09-06-2016 | #15 |
I bought mine from Harbor Frieght.
09-06-2016 | #16 |
I looked for an extension hose I could plug n play but couldn't find any so I made one up for my Actron CP7838 tester. https://www.amazon.com/Actron-CP7838...=Actron+CP7838
I unscrewed the hose fitting from the gauge (hose has a male 1/8NPT) and bought a 5' length of 1/4" ID fuel line to fit in between using 2 of these 1/4" barbed 1/8NPT male fittings and a 1/8NPT female to female coupling you can buy at Autozone. Gage -> barb fitting -> ext. hose -> barb fitting -> coupling -> original hose. I also used a hose clamp on the barbed fittings for safety and made sure nothing leaked before I took it out on the road.
09-08-2016 | #17 |
That photo looks like something from an aquarium supply house.
Or the local bong store!!!!! |
09-08-2016 | #18 | |
