Tried to remove the bolts only to have one of them strip into the frame....
should i just cut the bolt head off with a dremel.....I don't want to shake up that sensor too much..... |
#2 | |
![]() Join Date: Feb 2009
Rich
Yup the spot weld (grommet) is toast...I got the bolt out....
