Go Back   ZR-1 Net Registry Forums > Off Topic > OFF TOPIC
Old 03-03-2016   #1
Corbusa
Default my missing child ( kind of ) returned home
Years ago i had to let her go ,when I was needing to build our house.. I sold her to a guy that took good care of her. When sold she was perfect . Any way he sold her to someone else who abused her ... 18 years later a friend said he saw her out of state for sale of face book and called me . I went to extremes to bring her home..And Home she came...
Old 03-03-2016   #2
Corbusa
Default Re: my missing child ( kind of ) returned home
I got it home and it may take a few years to redo everything again ( a frame off) .. the bed has a dent ,( it had all new factory panels ) , door is dented ,fenders are dented ,fiberglass hood is broken ,body mounts - radiator supports are missing , cracked windshield ,all interior is trashed , the 454 that was in it was really nice ,11to1's ,ported heads , studded top and bottom , now the motor is missing and has a stock 454.. Its a mess... anyway , If it never gets fixed fine too ,she's home.....
Old 03-03-2016   #3
George Maz
That's awesome.
I have transmission that may interest you.
Manual New Process A833 w/ OD 4wd
dual pattern bellhousing, complete from shifter ball to crossmember. Only .05% trucks ordered this RPO
"Very Rare, said to be Special Order Only some places I found available info on these transmission. Dodge has used them way back in the 60's in Cast Iron form behind 426 Hemi motors so they obviously have some stength. Chevy units come in both Aluminum case for 2wd and Cast Iton for 4wd. GM RPO codes to look for are MY6 and MM7.
Total of 4 speeds, with 4th gear being Overdrive. Gear Ratios are very close to that of a 700r4 4 speed Automatic Transmission. Dodge variety came in different ratios depending on the vehicle application since they also used it in passenger cars. GM only had 1 set of gear ratios. Here is the gear ratios compare to a 700r4 4 speed Automatic
GM New Process A833
1st 3.09 2nd 1.67 3rd 1.00 4th .73 OD
GM 700r4 4 speed Automatic w/ Converter Lock Up
1st 3.06 2nd 1.63 3rd 1.00 4th .70 OD"
1990 ZR-1 #1587
1990 ZR-1 #1727
George Maz is offline   Reply With Quote
Old 03-03-2016   #4
Corbusa
Thanks Mr. George I'll keep this in mind and research it a bit.. Shoot me a PM and I'll keep your info.. Right now the truck still has a 400 turbo with reverse pattern and I had an adapter/ output shaft made to accept a 205 to it..
Old 03-03-2016   #5
Nice
I wish some of my old children would come on home. And a nice long list of some very special vehicles that would make.
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
