Old 02-12-2016   #11
Johnny5
Default Re: Headlight Noise/knocking
Metal upgrade is good for sure but if my gears are fine ill just replace the balls, if both are shot ill get the whole kit
Johnny5 is offline   Reply With Quote
Old 02-15-2016   #12
KJL
It is the plastic rollers inside the gears. Just replaced them on 4 headlights. Gears were in perfect shape but I replaced with plastic gears anyway. The metal gears cost a lot of money. I would stick with plastic. My gears had zero wear. I could have reused them. I would have been pissed if I sprung the extra for the metal gears. The head lights also for some odd reason fail closely together so buy parts for both and use a good plastic compatible grease.
1995 ZR1 #159
Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp
1992 ZR1 #280
Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp
1996 Collectors LT4 (Stock)
1972 Convertible 434 Small Block
572 rwhp
KJL is offline   Reply With Quote
