#21 |
![]() Join Date: Nov 2007
#22 | |
Dominic did an article and gave a talk at BG on the finer points of tuning. In it I believe he talked about "preset" and the affect on idle, among other things. I don't know if he's experiencing the "bog" issue - we'd have to ask him. But, I can tell you that he has the smoothest idling, fully ported and I/E cammed LT5 I've ever heard. Sweet. |
#23 |
![]() Join Date: Aug 2006
Just in case - connect a volt meter to TPS, as if setting idle, and have someone slowly push the gas pedal as you watch the voltage increase. I had a TPS fail partially and the symptom was hesitation at about 5% throttle position. If you see voltage increase, sudden drop, followed by steady increase again it's TPS failure.
With this type of failure, under rapid throttle opening TPS will go past the damaged part of the potentiometer so fast there will be no stumbling. Slow throttle opening will confuse the ECM when the TPS voltage drops suddenly resulting in hesitation until past the damaged part of the winding. Last edited by secondchance; 01-15-2016 at 10:56 PM. |
#24 | |
#25 | |
Definitely make certain, as second chance suggested, ur TPS doesn't have a null spot. Usually right at the beginning since that's where the throttle sits for the major part of the time. You should also note what the temps are when this happens, both ambient and coolant. Any chance you also moved the MAT sensor? |
#26 |
![]() Join Date: Mar 2010
Good points guys. I did check the tps with my tech1. Seems good and it's new but I'll check again to ensure I haven't missed anything. I also put in a new MAT sensor when I first got the car back together and the output of that seems normal as well. I'll look for the exact air and coolant temperature that the issue starts the next time I have it out
#27 |
I was asking about MAT to see if you had relocated it to front of radiator.
#28 |
Oh ok. No, it's still on the air horn.
#29 | |
![]() Join Date: Jun 2005
I know I'm coming onto this thread a bit late but, I'd like to take a little different approach.
After a long period of coast down, that would tend to load the motor up pretty bad so it's perfectly understandable that once loaded up "pig rich", on tip in, the engine is going to bog, but it's bogging not because of a momentary lean spot, it's bogging because the motor is big time fat. That's why, the engine runs well after a momentary "cleaning out.". My suggestion would be to find out why the engine is going rich on coast down. I wouldn't bother with fuel pumps, O2S replacements, wires, plugs and all the other stuff that's been thrown out there in this thread because I don't think they are related to the problem. Apparently, you have a scan tester. If it's one which logs data, run a "snap shot" which covers the period just as you step back into the throttle. Look at your O2Ses along with injector pulse width, fuel trims and TPS and see what those things are doing. You mentioned you have aftermarket injectors...are they the same flow rate as before? Finally, I see your on Lompoc. I'm in Goleta. If you don't have a data logging scanner, bring the car down here and we can use mine.
Hib Halverson Technical Writer former owner 95 VIN 0140 current owner 19 VIN 1878 Last edited by Hib Halverson; 02-13-2016 at 08:19 PM. |
#30 |
I finally had a chance to look at the car today. As I was driving the car around before I had the scanner hooked up the bogging issue was evident. When I got home I took a scan at hot idle to capture those parameters. Sometime as I was starting and restarting the car, a code 43 was set, which cleared on the next startup. I then went for a long drive to get a scan of the bogging issue, for the life of me, I could not get it to happen. I am dumbfounded.
Hib, to answer your question, I'm pretty sure the injectors are the same flow rate, I got them from jerry's. Since you are knowledgeable, and if you are willing, would it be possible sometime for me to come down there for you to take a look at the car and how it's running? Even if the issue doesn't creep up again (though I can't belive that it won't), I think it might be good to get another opinion on how the car is running before I have to drive a long distance when I move to a new base this summer. |
