Old 10-26-2015   #1
Default Clutch fluid and brake fluid
From quick research, it seems clutch fluid is basically DOT 3 or DOT 4 fluid. I was just curious what other ZR-1 guys are running in their cars. GM Hydraulic fluid? DOT 3, 4, 5 or 5.1?
Same question with brake fluid. DOT 3? 4? 5.1? Seems some European brands are offering 5.1 which are silicone based and yet ABS friendly.
Opinions?
Old 10-26-2015   #2
Default Re: Clutch fluid and brake fluid
Opinions?
Use Dot 4 for both.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 10-26-2015   #3
Not arguing w/ Dom, but IIRC, DOT 3 is what GM called for, and what I'm using and have used for 8 years now. With regular maintenance, I've no complaints.
However, I don't track my car (yet) either; so there's that, and I'm open to suggestions...
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 10-26-2015   #4
8cam
Clutch fluid and brake fluid are the same stuff, and it's a good idea to not intermix - use all DOT3 or DOT4 (don't use 5). If you track the car...and I mean road courses where you actually use the brakes...use DOT4 with a boiling point as high as you can get, preferably over 500 degrees. I just flushed mine with Ate blue and hammered it all day long at Road Atlanta, with zero issues.
If you use 3 on track, you'll get a few laps and then your brakes will fade badly. Don't do it.
'90 ZR-1 #1322 Daily Driver, 64k and counting
Black/Gray
[IMG]http://i208.photobucket.com/albums/bb49/mlitherland/IMG_0326_zps3d50d8cb.jpg[/IMG]
Old 10-26-2015   #5
One thing I do is change the fluid in both at least once a year or when it starts to turn yellow/dark. I hate to see dark fluid in a nice car when the hood is opened.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
