#41 | |
![]() Join Date: Feb 2011
Some of this tech will probably preclude engines from going much over 6000 rpm, but if you are torque blending with an electric assist, stored mechanical energy (like KERS), turbos, and all of this, why would you need high rpm? VW used to make a supercharged and turbocharged engine in a very small displacement, but stopped due to costs I think. The days of big inch lumbering NA engines are not long. Maybe in trucks for a bit longer... |
#42 | |
![]() Join Date: Jun 2013
#43 |
![]() Join Date: Feb 2006
#44 | |
#45 | ||
That being said, there is not a car with a DOHC engine today in the same price range as the corvette that can trump it. Keep in mind, the LT5 wasn't really the king of the hill in its day. There were faster production cars. F40s and 959s were both faster in acceleration and top speed. There is a reason there are more mustangs than corvettes, and more corvettes than ferraris. Price. And there is no return on investment for Chevy to retool a plant to build an advanced DOHC engine and bump the price of a corvette up 25% or more. If there were enough valid counterpoints supporting a DOHC V8, they'd be making one today. Last edited by spork2367; 08-14-2015 at 11:06 AM. |
#46 |
That is sad and probably true. And, you wonder why it should have to be like that. Today's engine's are the cleanest and most efficient they have ever been.
I am with letting the technology take us there through free enterprise and competition...NOT being forced there by a socialistic overreaching big government. ...eh, I have too much to do to get started on this topic, so I won't. |
#47 | |
#48 |
Makes as much of soundtrack as me riding my bike.. Just not cool lol.
Big lumbering engines are imo the direct result of a pushrod architectures limitations. Specifically the single cam. You just can't make an engine with a single cam have a smooth idle.. Torque down low for fuel economy (classic pickup truck formula) and make a high hp number up top that makes an excellent hp/L statistic. Case in point the Ls7. Huge potential ? Yes because it's 7L. Oem cams have a wide lsa because that one cam has to try and do it all. Want to chase 650-700hp? We're talking a pretty big cam with a choppy idle that sounds like a farm tractor missing a spark plug. Compared to say the F12s v12. Oem form.. 730hp from 6.2L. 505 from 7L. That's a 225 hp difference. The Ferrari v12 is Complex, expensive and spins to the moon which isn't a formula that works for pickup trucks so it's not a path gm chose to follow. |
#49 | |
#50 |
Definitely subjective .. But to me I don't care for down low torque. It's not needed. Gearing can give you torque , but can't give you hp. With the right gearing that 510lvs -ft can easily equal a higher torque motor at the tire. For me that torque curve is beautiful !! All that torque up high .. Where the motor will remain under wot through the gears is all that matters to me. If I was towing a trailer.. Sure give me an ls7. If I had a 4000lb pickup .. Sure give me an ls7. For my kind of sports car.. Give me that v12 any day of my life.
My Lt4 I built is a 370ci solid roller.. Makes peak torque at 6400 and peak power at 7400. Idle ? Well I hate choppy idles.. But I'm going to be on the receiving end of that idle lol. What this motor will give me is smiles from 6-8500rpm !! ![]() Would I have rather built an LT5? I think the answer Is obvious ! |
