#1 | |
Make sure your mirror lights are off.... the ones in the sunvisors.
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 07-23-2015 at 02:02 PM. |
Should be less than 20 milliamps with eveything off, key removed so CCM goes fully asleep. With this small amount of drain a good battery should last for weeks.
![]() Join Date: Oct 2004
What year is the car? I believe the newer cars with the under-hood fuse boxes are likely much easier to trouble shoot. Is there any added accessories? After-market radio or alarm etc.
Eliminate the most likely by removing the connector to the H/L module and disconnect the H/L motors AFTER you've walked around the car with the doors closed and the lights out in the garage, if it's an earlier year check the spare tire light. |
![]() Join Date: Aug 2006
I had a similar situation with battery going flat in a day or two. In my case it turned out to be HVAC fan controller gone bad. Even with the ignition turned off the controller was running the fan at very low speed. Not saying your cause would be the same but worth checking out.
I encountered a car that drew about 60 ma all of the time. It would drain the battery in about two weeks. The current draw was on the ABS power line. I eventually found a LoJack system, including a back-up battery for the LoJack, under the black panel under the rear of the hatch glass.
![]() Join Date: Jul 2005
Thanks guys, I'll check this stuff out. The car is a 91' with no non-stock electrical accessories, Lo-Jack etc.
We thought it might be the headlight motors, but after replacing the gears and re-assembling, it's still pulling 3A. I'll let you know how it shakes out, and if anyone has other ideas, feel free to post. Thanks. |
![]() Join Date: Jul 2007
My buddy had a similar issue with a 1992 Thunderbird
We used a DMM set for current and connected in series on the positive post to the positive cable. Then we started pulling fuses and watched the current looking for the drop off. If you had the FSM you could narrow it down further by just looking for the 'always' hot connections.. Maybe check the door chime module? I think I have heard that causing issues ( just don't remember where I heard that)
Bob don't forget pull it into a dark garage to make sure all the lights are off as WV suggested. You might have a duff door switch or rear hatch switch leaving the lights on including the spare tire light as well. GC
#10 |
I've never needed to do a "parasitic draw" test on a '91 but I believe if I had a parasitic draw on a '91 I'd start with doing a complete test of the DAB (Delayed Accessory Bus) first likely. A first year feature?
Determine how you want to do the parasitic draw test and be very systematic with your procedure. I've always used the - post and cable BUT ... I've a friend who whenever doing a parasitic draw test didn't go to the fuse box but to the fusible links first. On a '91 aside from the ECM FL and the AC BCM FL all fusible links are at the junction block behind the battery. I might remove the fender panel and do it from there in an attempt to isolate the circuit. I believe it would eliminate the need to remove the right side knee bolster to check the AUX BOXES where there's a pair of fuses for the convenience lighting and also the accessory leads in the console (another first year feature). **** You do need to do a "load test" on the battery and confirm the condition FIRST! |
