Old 06-04-2015   #1
564crewdog
Default Should I be freaking Out?
Hello all, I've noticed some intermittant smoke from the tailpipe. It usually occurs when you really get on the gas while accelerating and only lasts like a poof of smoke. I can't tell if it's white or blue and while I goosed the throttle in the garage, and got it to smoke, it smelled like spent gunpowder to me.
Here's the facts:
1990 Z with 38,000 miles
It's my daily driver (yes, the horror!)
Only mod is Marc's chip
I use Mobile 1 Extended Performance
Thoughts?
Thanks
Rich
1990 Corvette ZR-1 Polo Green #1648
1979 Trans Am SE Smokey & The Bandit Edition
1975 Porsche 911S (Sold)
1962 Lincoln Continental
564crewdog is offline   Reply With Quote
Old 06-04-2015   #2
Default Re: Should I be freaking Out?
Any rattling underside from the CATs?
Old 06-04-2015   #3
564crewdog
None that I can detect...
Old 06-04-2015   #4
Well MY 90s have no exhaust valve seat/seats so you me be just seeing normal blowby. Normally you see that upon startup which is why I asked you about the cats. I assume no error codes since you didnt state any.
Old 06-04-2015   #5
564crewdog
No error codes, all is GTG. I did read about the earlier Z's and smoke...It's very minimal when it happens, and I can't see it while in the car since it disapates so quickly...
Old 06-04-2015   #6
Could be PCV system
If its coolant your low coolant will come on...(sometimes the IH gaskets leak into the intake)
