Old 06-02-2015   #1
4CamJon
Default Service Ride Control codes
When I started my car this morning the SRC stayed on and didn't go out. I put about 70 miles on the car with multiple stops and keys cycles and it still didn't go off. One of my mechanics at work has a GM TechII scanner so we checked the codes and it give a 13 and 14 code the first time and then we cleared it and it came back on with a 13 code the second time. The car is a 91 with 47,000 miles on it and I have had no issues until now. I don't have a FSM so I am looking for a few answers on the codes and a couple of suggestions or pointers on what to do next. Thanks in advance for any help you can give.
Jon
4CamJon is offline   Reply With Quote
Old 06-03-2015   #2
RussMcB
Default Re: Service Ride Control codes
Those codes point towards the shock actuators (see below). They are successfully passing their startup tests.
The easy things to check:
I'd take the actuators off the top of the shock and check two things: 1) see if you can turn the top shock rod by hand (or with pliers very gently) to see if it takes a lot of effort to rotate them. 2) See how far the gear is sticking up above the outer ring's teeth. IIRC it should be about a 1/4" (but you should confirm).
Last week when I was working on mine I Googled and found an informative article written by Hib: http://www.corvetteactioncenter.com/tech/c4/fx3/
Good luck.
12 = Start of sequence
13 = Left rear time out
14 = Right Front time out
21 = Left Front time out
22 = Right Rear time out
31 = Left Front out of position
32 = Right Front out of position
33 = Left Rear out of position
34 = Right Rear out of position
