Old 05-01-2015   #121
SAM/CH ZR-1
Default Re: Frankenplenum
I think the TB will be fine at 63.5. Monoblade would be better, but I wonder if cams might be restrictive I have the split duration intake on these
A interesting Job. What are the cam specs if it's not a secret?
Sam
DR.Z/LT5-Performance
1990 #1822 with 383 cui
SAM/CH ZR-1 is offline   Reply With Quote
Old 05-01-2015   #122
These are 222 .415 primary and 236 .425 secondary. The other cams I have are all 236 .425
LGAFF is online now   Reply With Quote
Old 05-01-2015   #123
Some Epoxy helps clean up the looks
Old 05-01-2015   #124
will it fit under the hood or will you need to cut the hood? remember I have one to swap if you are going to cut....
Old 05-10-2015   #125
Here is a runner inside the plenum; its was mildly ported before; I am opening up the runners completely(This is a work in progress)
before
After
Old 05-10-2015   #126
Will this fit under the hood?????????
Old 05-10-2015   #127
Going to be close, the lid is thicker than my original plan by 1/4 inch
Old 05-11-2015   #128
Bearly Flying
Be interesting to see a dyno run after you get this manifold in service....
Good Luck Lee.
Bearly Flying is offline   Reply With Quote
Old 05-11-2015   #129
Good Luck Lee.
I would like to see an A/B comparison.
Old 05-11-2015   #130
Going to leave the lid bare...what color should I make the rest of the plenum....I know its lipstick on a pig, but...
