05-05-2015 | #1 |
Fuel pump replacement question
I have 2 EP381 pumps with strainers, and just need to take out the 10 bolts. I heard to replace plastic clips with metal coolant hose snake clamps. So the only question is where is the fuel pump fuse? i want to take it out to minimize the spillage.
05-05-2015 | #2 |
Re: Fuel pump replacement question
just disconnect the ground terminal on the battery while you are doing it .
