04-23-2015 | #11 |
Re: Cornering Bulbs?
I want to do the cornering lights as well as they are the only inside and outside lights I have not already replaced including the FOGs which are also LEDs
I hope Dom knows the part numbers for the side markers and if they are true plug and play. D
04-23-2015 | #12 |
I will try to pull a bulb this week and look at the socket and compare to the main reverse sockets..
Slowly converting the bulbs
04-23-2015 | #13 | |
04-23-2015 | #14 |
The LED's maybe confuse me a little, I saw someone post a while back regarding 130* and 360* bulbs and I would have thought for applications where you "want to see" a person might want 130* lamps when they installed perpendicular to the lens as in B/U so as to project out the lens rather than rely on the reflective characteristics of the housing which has likely deteriorated through the years. Of course you would need to be sure you bought a lamp with appropriate lumens. Am I not maybe understanding?
I understand the 360* where the objective of the install is "to be seen". A 130* lamp in stop/tail/turn might actually create a nuisance for the "follower". |
04-23-2015 | #15 |
What about the markers ?
04-23-2015 | #16 |
And... Moved to technical section
04-23-2015 | #17 |
04-23-2015 | #18 |
I know. I stated the sizes earlier. My question was to Dom
04-23-2015 | #19 |
I think the cornering lamps, and backup bulbs are the bayonet types like this
https://www.superbrightleds.com/more...led-tower/163/ Running lights are the wedge type https://www.superbrightleds.com/more...edge-base/229/
04-23-2015 | #20 |
