Old 04-17-2015   #1
GTOger
Default Help me fix jiggly headlight
<Celebrity Spokesperson>
"Did you know that C4 Corvettes can suffer from Jiggly Headlight Syndrome, known as JLS? Please help to eradicate this dreaded (well, annoying) disease."
</Celebrity Spokesperson>
I've noticed that whenever I drive at night the passenger side headlight seems to jiggle around in accordance with bumps and other anomalies in the road surface. Since I'm not in the car much at night, I never really think about it much other than "well, that's kind of annoying." Today I got the wild hair to take a look, and found that there appears to be a bracket that is totally missing from my car.
Trouble is, I have no idea what it's called, and hence what I should search for. Ideas?
I will try and illustrate what's missing by taking a picture of the driver's side, which is fully intact. It's a 90-degree steel bracket held to the underside of the hood with a nut that goes onto the threaded stud that's affixed to the underside of the hood. (The stud is there). It affixes to another bracket on the hood by way of a nut and bolt. Here's the pic, which you can click on to enlarge:
You can help me! I know it!
[B]1990 Corvette ZR-1 (#1930)
Red/Black, Stock Engine, Henderson Performance custom ECM, FIC Injectors, B&B exhaust, Kenwood DNX6160[/B]
Other Rides:
1992 Pontiac Firehawk (#010), 1967 Pontiac GTO
1998 Porsche 968, 2000 Harley Davidson FXST
1986 Pontiac Trans Am, 1931 Ford Model A Tudor Deluxe
GTOger is offline   Reply With Quote
Old 04-17-2015   #2
efnfast
Default Re: Help me fix jiggly headlight
I believe that's the anti jiggly bracket. Sorry, couldn't resist.
Old 04-17-2015   #3
Dime
You might try finding someone selling the entire headlight assembly and asking if they'd be willing to part it.
[B][U]1991 No. 519[/U][/B]
Dime is offline   Reply With Quote
Old 04-17-2015   #4
Just checked ny car but I have both. Prob somebody rebuilt the motor and left it off. My drivers side wiggles more than the passenger side but I think these float about abit based upon road conitions assuming the trim ring etc is tight
I did some more research for you..The part you are looking for is the hood hinge bracket. RH 14060285 & LH 14060286.The one hole used a carriage style bolt to keep it from turning when tightening.
I also suggest you look elsewhere first for the jiggly issue. As the 92-96 cars did not have this bracket. Just FYSA
Old 04-17-2015   #5
G8nightman
G8nightman's Avatar
http://www.ebay.com/itm/1984-1985-19...4b50ec&vxp=mtr
Here you go
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 04-17-2015   #6
GTOger
Thanks Goldcylon. Yeah, I think the whole thing could do without the bracket, but then that would throw my weight balance all out of whack and I'd probably loose control of the car in the turn and crash and bad.. WHAAAH.
No, actually, I'd settle for just having the nut that holds the bracket to the hood. That's the part that's really causing the wiggly bit. It's fastened to the underside of the hood with 2 of 3 mount points. I think that other brace must be rigidity. And likely overkill. But original.
Other Rides:
Old 04-17-2015   #7
GTOger
I found exactly what I needed here:
http://www.ebay.com/itm/251188570241
Thanks for pointing me in the right direction, guys. The parts number was especially helpful. I just had no idea what to even search for and I was coming up blank.
As always, you're the best.
Other Rides:
Old 04-18-2015   #8
1991ZR1
It may be worth looking around under the coolant overflow bottle to see if someone dropped the original bracket under there.
1991ZR1 is offline   Reply With Quote
