04-13-2015 | #1 |
Rev. limiter
OK guys, maybe a dumb question, but I took my car to 7,600 RPM yesterday and did not hit the rev. limiter. So, other than it having a different chip in it is there any other reason/s for this. Sure wish a knew the cars history better !
Thanks in advance, Bob
1990 Steel Blue #2818 ( stock for now ) |
04-13-2015 | #2 |
Re: Rev. limiter
Tach could be off a few hundred, I think Marc set my chip at 7400. maybe you can find someone with a scanner to double check it.
04-14-2015 | #3 |
Re: Rev. limiter
If the tach is off, and it probably is unless the limiter has been boosted, calibrating it is not difficult for anyone with a little experience with soldering on PC boards.
(Note: The procedure abounds, but if you find you need it, let me know and I can PM you, or maybe it should be made a "sticky" on this web page!)
04-14-2015 | #4 | |
Re: Rev. limiter
04-14-2015 | #5 |
Re: Rev. limiter
Thanx for the link, herr Dynomite, aka Archive Master!
04-14-2015 | #6 |
Re: Rev. limiter
My tach is off by 1000 up there, but looks cool when you are shifting at 8000 RPM. I have a axillary tach mounted.
Tony Davila (Projects) Water Meth: http://www.zr1.net/forum/showthread.php?t=19422 Exhaust cut outs: http://www.zr1.net/forum/showthread.php?t=22689 Auxiliary 12V install: http://www.zr1.net/forum/showthread.php?t=22878 Auxiliary pusher fan install: http://www.zr1.net/forum/showthread.php?t=22859 Oil Catch can Project: http://www.zr1.net/forum/showthread.php?t=20320 |
04-14-2015 | #7 |
Re: Rev. limiter
That's why I have a shift lite.
04-14-2015 | #8 |
Re: Rev. limiter
Mine is only off by 200 rpm or so over 7000 indicated rpm. My limiter is set 100 rpm past stock so about 7200. I think it displays close to 7400 when it cuts so no need to take the gauges apart to fine tune the resistances, but mostly I go by sound and pull the shift when the needle is at about 7k on my gauge.
04-14-2015 | #9 |
Re: Rev. limiter
Dyno is the master, but try this Marc tip, Engine speed displayed in HVAC LCD panel, press fan up and down buttons together until -00 shows, then fan up until -06, then press fan icon, display 3 digit #( mine was 155 ) x 25( mine was 3875) to equal RPM, do this at 4K RPM, mine off only 125
