You should try running the Haibec chip with a colder set of plugs. 1 heat range may make all the difference. If the problem is tip in fuel, you could take a look at the fuel pressure when it happens, it may not be increasing as it should. These 2 things were problems for me when I first got my ZR1. Goodluck, nothing is more annoying than a problem at WOT.
The problem only happend at low speed and medium speed....
When I hammer down...it seems to be fine...of course it is so loud, I could not hear the knock |
Ahhhhh, then the solution is simple, just stay at WOT throughout your entire driving experience. Goodluck with the fix.
#4 | |
That is pretty much what Marc said.....drive it like I stole it...because the previous owner didn't |
