Old 01-01-2015   #1
BigIke
Default Single Mass FW ID
My car revs quick, but i don't know how much quicker than any other LT5... When I start off with very little throttle, maybe too little sometimes, there is a rattle for the tranny/engine area?
Can anyone describe the noise that is associated with the single mass FW?
Thanks!
1991 White ZRJuan #1616
Mileage: 56K Sept-14 -- 113k May-18!!!
God Damn I Love This Car!
BigIke is offline   Reply With Quote
Old 01-01-2015   #2
Default Re: Single Mass FW ID
The FW makes no noise. The noise is from the Trans which is a bit like rocks in a can. The Dual Mass absorbs the engine vibration.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 01-01-2015   #3
BigIke
Yeah, thats what i was thinking, i think i have a Single Mass in mine.
Thanks
Old 01-01-2015   #4
USAZR1
USAZR1's Avatar
Thanks!
Under those conditions,a ZR-1 with dual mass flywheel will make the same noises.
Clint & Sherry
1994 ZR-1 White/Red #152 (sold)
1991 ZR-1 Callaway Aerobody #1332 (sold)
1990 ZR-1 Red/Red #952 (sold)
2002 Z06 Torch Red/Mod Red widebody
USAZR1 is offline   Reply With Quote
Old 01-01-2015   #5
My Fidanza will cause a tranny rattle at idle, in neutral and clutch disengaged. Otherwise, it doesn't rattle. And the amount of rattle depends usually on how hot the trans oil is.
Old 01-02-2015   #6
Hib Halverson
A dual mass flywheel does not "absorb" engine vibration. The engine mounts and the car's structure do that.
The dual mass wheel damps gear rattle from the transmission.
At idle and low rpm the engine speed fluctuation caused by four firing impulses per revolution (engine speed increases as the engine accelerates during a power stroke then decreases as the engine slows down on a compression stroke) causes the teeth of the gears on the transmission main shaft to vibrate or rattle in the teeth of the gears on the countershaft
The dual mass wheel, partially damps the effect of this speed fluctuation by setting up a secondary fluctuation out of phase with the primary. The result is a reduction in gear rattle.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 01-02-2015   #7
BigIke
Mine is loud... I'm a little embarrassed when pulling out of the local meet...
Old 01-02-2015   #8
Is this in neutral? Clutch disengaged? Accelerating?
Old 01-02-2015   #9
BigIke
No noise in Neutral, maybe a little throwout bearing noise.... No noise acceleration except from a dead stop with light throttle. Not nearly so light a throttle that the car bucks or anything like that just a normal light throttle take off.
Old 01-02-2015   #10
Mine only rattles in Neutral w clutch engaged. The noise level is also dependent on how hot trans oil is, as in after a long run on a hot day. Again, playing w the tune evens out the engine pulse helping to minimize the rattling. Same as what happened with the ZF-6 in my 84 Xfire.
