![]() Join Date: Mar 2007
Bought one of these to make fittings for plenum.....will see how they work
http://www.eastwood.com/universal-hy...ype={MatchType}
![]() Join Date: Dec 2003
Looks like a neat tool..... and I like good tools. I will want to see pictures of the aluminum tube plenum connectors.
looks pretty awesome: https://www.youtube.com/watch?v=ioeS-ymqtz0
![]() Join Date: Feb 2011
That thing is sweet. The next time I need to repair or make a hard line, I will by a quality hand-cranked tool, but that thing would make quick work of it and maybe flare the cleanest.
#5 | |
![]() I especially like the Push Connect flare I think for the Plenum Fittings. Let us know Fittings Sizes you use and what type of Tubing? ![]() Eastwood.com Universal Hydraulic Flaring Kit Buy Direct From Classic Tube Universal Hydraulic Flaring Tool Kit ![]() ![]() Oh...and that video is a great video ![]() How To Use Classic Tube's Hydraulic Flaring Tool Set
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-10-2014 at 09:30 AM. |
Slick wonder how they would come out in stainless.
I think they say you can't do stainless
Well the hydraulic part of the tool turned out to be bad; I bought it used....but I was still able to make a few test runs on scrap aluminum tubing I had:
The quality was relative to how even the face of the tube was and the straightness....also you can vary the degree of the flare a lot ![]() ![]()
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 12-12-2014 at 11:36 PM. |
#10 | |
That is the infamous Push Connect Flare used on the Plenum Fittings
![]() Excellent Job Lee ![]() If those fittings are the correct diameter, one can just use Red Loctite and push them into the Plenum where required if a fitting has become dislodged and lost or broken. Quote:
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-14-2014 at 10:51 AM. |
