Old 07-04-2007   #11
UKZR1
UKZR1's Avatar
Default Re: HighWay Gas Mileage with Valet Key On?
I must be doing something wrong as I only managed 16 durring my trip through Europe.
Red/red 90 #1281 (UK)
Marc Haibeck 368
B&B, Brembos
DRM suspension
Known as 'Gixer' on corvettechat.co.uk
www.corvetteclips.co.uk
UKZR1 is offline   Reply With Quote
Old 07-04-2007   #12
lbszr
lbszr's Avatar
Sounds like you must be driving it the way it's made to be driven What's the speed limit there?
Old 07-04-2007   #13
UKZR1
UKZR1's Avatar
In the Uk 70mph, although that tends to be 80-90 most the time, a bit faster when i'm in the Z.
On my trip France is 130KPH, Switzerland had slow limits, though on the mountain roads I was on the 80kph limit was more than enough - for an idea one road we used was 13km long, climbed 15% and had 350 curves (mostly tight hair pins) on it. Then of course Germany which either had a 130kph or no limit at all!!!! Although unlike previous years the Z didn't get to stretch her legs as much because it was wet part of the time and also busy
Marc Haibeck 368
B&B, Brembos
DRM suspension
Old 07-04-2007   #14
Nick
Originally Posted by jonszr1
jeff when is your event?
July 27-30
Old 07-06-2007   #15
Norsky4360
Last month we spent 15 days on the road in "The Beast". Put on 5,000 miles and averaged 24 mpg for the trip.
I have to admit that when on the flat land we were cruising with the key off (unless some extra boost was needed for passing on a two lane road ) but when in the mountains the key was always on. Most of the flat land running also included having the A/C on as outside temps were often in the triple digit range.
There were a few days of "spirited" driving that impacted the daily averages. Best tank was 27+ mpg and the worst was 19+ mpg. So IMO the KOTH lived up to its window sticker claim of 25 mpg/highway.
Norsky4360 is offline   Reply With Quote
Old 07-06-2007   #16
DaveK
On the trip to MN last weekend I averaged 24, that was with Marc's chip so the 'key' was effectively on and I also have 4.10s.
Thanks
Dave
1991 #1516 Black/Black
davidmkelly.com
Old 07-06-2007   #17
Norsky4360
Old 07-10-2007   #18
RHanselman
RHanselman's Avatar
28.5 on the return from BG with my 93 after Marc dyno tuned it...
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1961 White with Red Int
Old 07-10-2007   #19
Drove to Dayton area this weekend and averaged 22mpg which I thought was a bit less than expected. I was driving at 75-85mph most of the time. I think the Marc Randolph chip I have causes secondaries to open a bit too early. Power key is always on.
