Old 11-13-2014   #1
Mystic ZR-1
Mystic ZR-1's Avatar
Default In car removal of cam covers
Winter project: powder coat top end
Can the left side cam cover be removed and reinstalled
without disconnecting the AC lines to the compressor?
I know about moving the brake master cylinder etc.
Any tips and tricks?
Thanks!
Old 11-13-2014   #2
Default Re: In car removal of cam covers
Yes just unbolt the AC compressor and move it out of the way some say it is easier if you remove the brake bosster also. . On the right if you look close part of the heater box is removable also.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 11-13-2014   #3
Mystic ZR-1
That makes sense, didn't occur to me to just move it out of the way
once the plenum is off.
Thanks!
Old 11-14-2014   #4
Thanks!
Be careful when you set AC Compressor aside that you do not upset the AC connections to the Dryer.
You do not necessarily need to remove the Brake Master Cylinder but does help to remove the C-Frame from Transmission so you can tilt/lower the engine.
See Item #1 Removing Cam Covers (Engine In Car) for Inspections of Camshafts
Old 11-14-2014   #5
BigJohn
BigJohn's Avatar
Thanks!
SAWZALL???????????
Old 11-14-2014   #6
Mystic ZR-1
Originally Posted by BigJohn View Post
SAWZALL???????????
Bring it to breakfast tomorrow AM
Old 11-15-2014   #7
ZRXMAX
ZRXMAX's Avatar
If I were to do it my approach would be to leave to brake booster alone. Your time and fussing around under the dash will be considerable with R & R. Like Clint said... drop the exhaust, drop the C beam and lower the trans enough to gain access to the rear of the motor. Make sure you have a good torx setup and a sure way to apply pressure down on the cam cover bolts before attempting to unscrew them. I would also soak them for hours with the best loosening agent you can come up with... opinions will vary on what to use. Take your time and good luck with it. A nice powder coated engine is a very gratifying project imho.
91 ZR-1 #661 Watsons, 3" exhaust, Borlas... Hurst, 4.11s, Samco, RD radiator, gel coated motor... turquise / black
ZRXMAX is offline   Reply With Quote
Old 11-20-2014   #8
BOB HDZ
BOB HDZ's Avatar
Cool Re: In car removal of cam covers
I have never done this but got it from a good source. if you take out the motor mount bolt one at a time & jack the motor up with a piece of wood you can access all the torx bolts!!!
BOB HDZ is offline   Reply With Quote
Old 11-20-2014   #9
ZRXMAX
ZRXMAX's Avatar
You only have to much room to go up. It seems you might end up pinching some things.
Old 11-21-2014   #10
Likewise... I think it was Jeff Flint that recommended that method, but removing the heater shroud cover is required to allow the motor to be tipped toward the right, IIRC. Maybe some day... Bob G has one of the prettiest powder coats I've seen, if you like silver. It looks (to me) like a tiny silver metal flake. Really nice!
