Old 09-11-2014   #3
hottrodcrazy
Default Re: 1991 ZR-1 Exhaust Manifold Bolt Specs
http://jerrysgaskets.com/store2/root...roducts_id=243
The stock bolts have a sintered metal sleeve/spacer that was held onto the bolt with a retaining clip. We do not have the spacers, but they can be made easily fron 1/4" schedule 40 black or galvanized pipe which is readily available at any hardware store.
Thanks for that info. I'll look into that. The bolts for the ZR1 are going to be different from standard c4 exhaust manifold bolts I imagine right? I can find those with no problem so I just want to make sure they aren't the same bolts.
hottrodcrazy is offline   Reply With Quote
