Old 08-24-2014   #31
Default Re: Clutch Disengaging issues
New master and it shifts like butta....old master had a bad snap ring
Ochom's razor. Always something simpler than the conclusion we jump to.
Old 09-07-2014   #32
JohnG
JohnG's Avatar
John you have a bad master or slave....give me a call
It was the master. I filled the reservoir and the next day it was empty. I replaced it with one of those cheap Chinese ones. I will send the old one to Jim Jandik to rebuild. I love driving the Z and didn't want to waist any nice days. Just passed 10k, it had 7.8k when I bought it last August.
Thanks for all of your advice.
1990 #1866 blk/blk
JohnG is offline   Reply With Quote
Old 09-08-2014   #33
Its back ..........son of a *****
Old 09-14-2014   #34
So yesterday shift no issue from a cold start....today will not engage a gear at all....found a large metal shaving in the Master cylinder in a screw shape....thinking maybe all of the material when they tapped the cast was just left inside...wonder if the line if clogging?
Old 09-14-2014   #35
Have u thought of replacing hydraulic line?
Old 09-14-2014   #36
The line is only a few years old....unless you are saying its clogged??
Old 09-14-2014   #37
Something is breaking down if the fluid is getting black after only a few hundred miles. Sounds like the line is the oldest thing in the circuit.
Is it a SS braided line?
Old 09-14-2014   #38
Yes its stainless ......from Classic Tube..
Old 07-10-2016   #39
Well the clutch engagement issues went away this year, but it appears that after only about 8K miles the disc is shot; making me wonder what is causing all the problems? Too many projects right now and work, looks like no Corvette Shootout this year
Old 08-22-2016   #40
problem might be solved clutch fork and pivot were worn, the disc was completely toast in under 10K miles
