#11 | |
Thanks, |
#12 |
![]() Join Date: Mar 2007
I had downloaded TunerPros Definition file, it did not work...tried Jeffs Definition file...it worked. The Tunerpro system itself works.....just the 1990 Z definition file was bad...not sure why.
#13 |
I came from a GMC Typoon and used Datamaster for all datalogging and Tunerpro for editing. You get 20 free uses of the software before you have to buy it
http://www.ttspowersystems.com/DataMaster.html I found it easier as well as most to do it this way. Another site that has some info for vettes, but mostly for SY/TY: http://www.code59.org/index.php |
#14 |
installed an innovative wideband 02 sensor tonight. going to check AFRs on my drive up to Road America Sunday
#15 |
Went out with the wide band on.....no runs to 7K but some 5800rpmruns
Idle: 14.7-15.3 Cruise: 14.7-15 Tip in: 10.8-11.3 WOT: 12.0
#16 |
Lee
Part throttle and cruise looks ok. Need to lean out the AE pump shot and the WOT AFR. Use Lambda to tune WOT in particular since we have E10 in Illinois. AFR is a bit misleading because of that. You will need to use PE table for that. Don't make big changes. Make sure ur first headed in right direction. |
#17 |
![]() Join Date: Jul 2007
The TunerPro ZR-1 XDF files are not very good..
I think Dominic has the better one for tungin use, but unsure what years his support My ADX file should work for 100% on 1990 and I would say 80-90% coverage for 91-95
