Old 07-17-2014   #1
illeagleracing
Default Re: New to ZR-1 Removed Sec Vac system and now problem
All that checks out except for the sensor under the ecm. I thought it was suppose to be left without a vacuum line but if it needs one Ill surely put it on.
illeagleracing is offline   Reply With Quote
Old 07-18-2014   #2
Mine is exposed to the air - no vacuum line, per Marc. I pulled everything out on mine; throttle plates and all. And, I believe that included the vacuum solenoid as well, as I remember tying off an electrical connector (but I don't see how leaving it connected would be an issue, btw).
Old 07-18-2014   #3
Tony Davila
Tony Davila's Avatar
That is what I thought and plugged mine and I had issues. Just try it and see if it works.
Tony Davila is offline   Reply With Quote
Old 07-18-2014   #4
Pete
Pete's Avatar
I gather you chip is not done,
What ever the case put a vacuum hose
from vacuum pump to MAP sensor
Under ECM if you just connect to a
Vacuum source at the engine will
Not work at WOT and have the
Sensor under plenum connected
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
