#51 |
![]() Join Date: Oct 2013
To the best of my knowledge,my friend's 94 did not come equipped with the FX3 option. He told me it was a base car,Dave.
#52 | |
![]() Join Date: Oct 2004
It might make sense that your friend bought a spring to modify and have ready to do the change rather than tear apart and then do the work. Maybe he purchased that one modified. The type of insulator on the end is key. I have 2 FHA springs one of each type, one is removed from a '91 ZR-1 (I'm sure of that) and I have one with the pedestal type that I always thought came from a '93 LT1 car recovered theft with real low miles. I've got control arms and spindles as well for that car. There's no FHA code for '93 cataloged either, mine has NO color code and I don't believe it could have. I can see where there was a label at some time. I forgot that I had the springs to compare because you mentioned '94 so I didn't even consider checking mine. |
#53 |
I don't have the spring in hand so I can look it over but I do know that spring was the oem unit for that base 94. He removed the spring,modified it, and re-installed it. About six months ago,he removed it again and installed the coilovers.
If I could use that particular spring,it would save quite a bit of time and I would still have my 94's unmodified spring to keep. |
#54 | |
#55 |
Wow, the Z51, Challenge and Z07 cars had some high spring rates and anti-roll bar diameters. And the roll bars were both solid. I'd have to wear a mouth guard and neck brace to drive on DC roads again. I've never seen moon sized crater potholes until DC.
