![]() Join Date: Jun 2012
Just installed my new oil cooler lines from Jerry's. Could I have built my own, sure. But I'd rather spend a little more and support the very few vendors that are out there, to keep our cars running 100%. Easy job to do and Jerry sends a installation sheet too (although the one thing I would change is, once both lines are connected to the block, I would then connect them to the adapter and then to radiator. Connecting the adapter first to the radiator, then lines is almost impossible, unless you remove the radiator shroud first on a 1990). Here's some before and after pics.
[IMG] A big thanks to Jerry for making these available and your installation sheet made it super easy. They look great and no more leaks. ![]()
Joe 1990 Bright Red ZR-1 #2599 |
![]() Join Date: Oct 2013
Looks great!
Clint & Sherry 1994 ZR-1 White/Red #152 (sold) 1991 ZR-1 Callaway Aerobody #1332 (sold) 1990 ZR-1 Red/Red #952 (sold) 2002 Z06 Torch Red/Mod Red widebody |
![]() Join Date: Dec 2003
Thanks for the feedback Joe.
![]() I probably missed the shroud interference because I had cut mine for clearance when I installed the Ron Davis radiator 10+ years ago.... and just forgot about it. Getting older allows one to incorporate a new set of lame excuses! ![]()
#4 | |
![]() Join Date: May 2011
Robert J. DeMarco [SIGPIC][/SIGPIC] [COLOR=blue]G[/COLOR][COLOR=red]rand[/COLOR] [COLOR=blue]S[/COLOR][COLOR=red]port[/COLOR] Registry Lifetime Member NCM Lifetime Member #2655 Pacecar Registry Member [COLOR=red]ZOOM Charter Member - ZR-1 Owners of Michigan[/COLOR] [COLOR=plum][I]ZR-1[/I] Registry member since 2012 [/COLOR] [COLOR=black]1990 LPE "368" Aerobody ZR-1, Last ZR-1 built by John[/COLOR] 1991 Callaway Aerobody ZR-1, DRM 500 1991 Shinoda Aerobody Spyder, 1998 Pace Car |
#5 | |
