Old 06-28-2014   #21
Default Re: 91 Vette Doctors 368 Rebuild
Prior owner took out everything....brakes disconnected, etc....lots to do
any suggestions for flushing out the oil cooler????
Old 06-28-2014   #22
Car had a short shifter and looks like c5 pedals...
Old 06-28-2014   #23
this is why the original owner started pulling the motor....fear over cam failure:
http://zr1specialist.com/HAT%20Web/f...s/DCP_1123.JPG
Although appears these were not having issues....
Old 06-28-2014   #24
Now where do I put all of this stuff..
Old 06-28-2014   #25
Jagdpanzer
Jagdpanzer's Avatar
Lee,
I had good results with removing mine from the car then letting it set for couple hours filled with brake cleaner. Sloshed around good before draining then repeated. For final flush hooked it up to the solvent tank pump outlet with new solvent let it run until the return was clear. Then blew it out with the shop air hose. I was surprised at the amount of effort it took for just having 20k miles of use and frequent oil changes.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 06-28-2014   #26
thanks Phil.....
Forgot to mention also....heads have Titanium keepers.....
Old 06-29-2014   #27
z proud
z proud's Avatar
Lee, asking to have a understanding, did the cam fail or was it a lifter failure?
Thanks Bill
z proud is offline   Reply With Quote
Old 06-29-2014   #28
This car did not have a failure...the cams and lifters look good. The prior owner took the motor apart as a preventative measure and did not have time to finish the car.
As far as what I have heard about the Jeal cams....some say the Rockwell is too low in comparison to the lifter. In speaking to Mr Jeal he contends those with failures had poor oil pressure.
Others run these cams with no issues(Including Corey Henderson). Some have had failures.
Either way..I am going the safe route and replacing them
Old 06-29-2014   #29
My leak down tester was not working, so no numbers...but did pressurize the cylinders to see what I had. 1,2,3,5,6,7,8 no leakage at the valve, can hear some hissing past the rings, but this motor has sat for years so probably some abnormally dry liners.....
Cylinder 4 had some leakage past both intake valves....however with some brake clean sprayed in it and some pressure on the valves....it improved.....so thinking they are just alittle gunked up. Will soak they overnight to see how they do...they are holding fluid.
Once I get a new tester will post some #s....
Old 06-29-2014   #30
nelson007
nelson007's Avatar
Hello Lee,
I have used this milkstone acid on all of my old Corvettes. Let part soak for a couple od days, and wipe or squirt it off.you can buy it at TSC or True Value. I buy 5 gal at at time, i think it cost about $50
Nelson007
WAZOO MEMBER
1993 #124 Ruby
1994 #??? Red/Black
1995 #061 Black/Red
2012 ZR1 Preproduction
