06-12-2014 | #11 |
Re: What do I need for header install?
Just extension harnesses. I bought my last pair off of eBay
06-12-2014 | #12 |
06-24-2014 | #13 |
Hey Daryll,
It doesn't seem to be real clear exactly what extension I need...they don't seem to be "universal" and I'm seeing conflicting information. Would you happen to know exactly what I should order? I've also read that with OBX, you only need an extension for one side. (as opposed to SW headers, which require extensions for both sides) Can you or anybody else confirm this for me? Thanks for your help! Chris |
06-24-2014 | #14 | |
06-24-2014 | #15 |
I made my own extensions since the 91 vette uses a 3 wire heated O2 sensor. GM soon went to the more common 4-wire unit leaving a small market for 3-wire extensions.
you can search my name (mike100) and 02 extension and you might be able to find the list of parts on a post somewhere. I got everything at Napa, but I found some online sources for much cheaper weatherpack connector parts. You will need to buy the crimping tool though. |
06-24-2014 | #16 | |
I did the search and copied my post. Everything you need to make your own:
06-24-2014 | #17 |
With the OBX, passenger side only.
06-24-2014 | #18 |
06-24-2014 | #19 |
There's likely a Fleet Pride near you and anything that you need in weather-pack you should likely be able to buy there if your NAPA doesn't have them. Weather-pack is still used in the truck-trailer industry for lighting so it should all be there.
Any truck/fleet parts supplier will have your needs. There should be no need for any kind of an "on-line" adventure. Here's the Delphi Weather-Pack brochure and with these part numbers any jobber in the area can help you. Since you're doing extensions if anyone has the CPA go ahead and buy them also. All of the seals, terminals, connectors are in this brochure. http://delphi.com/connectors/assets/...ather_Pack.pdf Last edited by WVZR-1; 06-25-2014 at 12:09 AM. |
06-25-2014 | #20 | |
