Old 06-24-2014   #1
Default Re: I think I lost my alternator today, or its real close to crapping out. Belt #?
The Late model case is a bit bigger (thicker), look at the rear bearing 'Cap' on the early model it is part of the case, late it is separate cap
Also the case is mainly thicker around the Stator.. I tried a later model, it will not fit without some grinding on the Casing ( I did not want to go that route)
Early:
Late:
