Old 06-15-2014   #1
Roadster
Roadster's Avatar
Default First drive on the highway...some questions???
Took the ZR-1 out to the 74 yesterday, which is about an hour and ten minutes away from my home. Ran extremely well, but do have some questions regarding the coolant temp, clutch noise, and passing speed.....
1- I have Marc's chip in here, so the fans will come on @ 205* and come off @200*. I noticed that driving in 6th gear the temp would go up to around 213* at around 60-65 mph. If I dropped down to 5th gear, the temp would drop to 203* - 200* and stay there. I am not complaining by any means, but trying to understand why the difference in temps in the different gears. 5th gear was running about 2000-2300 rpm's and 5th gear was running about 1600-1800 rpm's for the same speeds. If the fans are coming on due to the temp change, then they aren't depended on the rpm speed? Correct? Maybe I'm missing something here, just curious....
2- Passing speed, when driving along in 5th or 6th gear, traveling @ 60-65 mph and you press down on the accelerator, are the secondaries supposed to open up. The car goes, but I thought I would get a better response. And yes, I realize that the r's are lower, and that if I downshifted to a lower gear, it would have a different result, just wondering how it should be???
Out of first or even moving in 2nd, it's just fine, did my first shift from 1st to 2nd above 6000 r's and I was moving, no miss, bog, anything of that nature. And of course, it feels like the secondaries open up just fine....
3- I noticed this nioise at low speed driving that it seems the throw-out bearing is singing a high pitched note, when I depress the clutch pedal, the noise goes away, and comes back when the clutch pedal is released, moving or standing still. Throw-out bearing????
Thanks for any and all responses...............appreciated....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 06-15-2014   #2
Demps
Demps's Avatar
Default Re: First drive on the highway...some questions???
1. Fairly normal for stock. Water pump flowing more volume at higher RPMs.
2. To your question: Secondaries open on a schedule. Not sure on Marc's chip specifics. Bottom line: this is/was a critique of the LT5. There are some developmental stories of an uphill climb in an LT5 that had to downshift where regular car did not.
3. Good chance. Another possibility may be the pilot bearing spinning.
Ted
Old 06-15-2014   #3
mike100
The dohc design is a little soft below 3000 rpm- you will just learn to drive it a little differently than a small block vette. I give no quarter if and downshift into 3rd sometimes on the freeway just because there is still usable top end left on the powerband.
My last 95 coupe with the blue label ZF made the same exact noises- it is normal although it may vary from car to car. It can be tuned out with careful assembly and blueprinting, but I wouldn't touch it unless something else goes wrong with it. I do not believe the noise is an indication of impending failure or shortened lifespan. ZF's make all kinds of noises from the bearing whine to 'box of rocks' grumbles at low rpm lugging and such. Bill B (ZFDoc) has all the info on this box and his services at http://www.zfdoc.com/.
Old 06-15-2014   #4
Had an issue with water temp on the 93 I did not notice until I changed to Marc's chip.
Running in 6th gear it would get up to 217 and never below 205, so the fans would never cycle off. In traffic it would stay about the same.
It would run a few degrees cooler in a lower gear as the water pressure was up and by passing some at the thermostat.
Long story short changed the thermostat now it only gets to around 210 in traffic and when the fans cycle on it goes back under 200 and they cycle off as they should and stays 190 to 200 at the most in 6th moving down the road.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 06-15-2014   #5
Roadster
Roadster's Avatar
Ted
Ted, thanks for the info. So it is not just me noticing that about the LT5!!!
Mike, yes I have found that out, as mentioned above, glad its not just me noticing those differences....and learning how to drive the LT5 as you are suggesting, which is so much fun.....still alot to absorb.......
Steve, when I first drove the Z, in local traffic with no AC, the temp would climb up to 238* and then come down when moving. Switching to Marc's chip, without the AC, 217* is the highest I have seen, and 210* the highest with the AC on, it will usually come down to 203*-201* when running the AC.
I am satisfied with where the temps are, and I have no idea if the thermostat
has ever been changed.
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 06-15-2014   #6
efnfast
Tom, AC forces both fans on. Probably why you see lower temps with the AC on.
Old 06-15-2014   #7
May want to consider pulling radiator and cleaning out the cooling fins. Over the years, fine dust gets in there hindering air flow.
Old 06-16-2014   #8
Racinfan83
That's the way mine was until I took it to Marc. I had him pull radiator and clean it, replace thermostat, and chip it among other things. I don't remember what temp thermostat he put in it - but mine hardly ever goes over 200 now no matter what... So maybe the radiator clean made a huge difference. That sucker was NASTY for having only 18k miles. The lower right third was caked with grease and dirt - Marc said the oil cooler lines has leaked and been replaced - but the oil got all on the radiator and they didn't clean that when they changed the lines. I made a debris screen to keep the bigger stuff out right after I got the car - but the rad was full of dirt and greasy junk...
Old 06-16-2014   #9
Yes! x2 on that. The amount of sand and plant fiber that flushed out of mine was astounding. And, when driving, it is a good thing to avoid driving over the grass clippings resulting from people mowing along the edge of the road. (I found a thick mat of grass clippings pressed like cardboard against the top 1/3 of my radiator.)
Old 06-16-2014   #10
mike100
I found that residual mist and wet frame sections from the all too common oil cooler line leak will still allow dirt to build up even many months after the repair. As a general trend, i would say to clean the radiator every two years (from both sides). I clipped the pass. side shroud tab to make it easier to remove from the cluster of a/c lines and bracketry.
Besides the large debris, you still need to spray it through with water before each summer.
