Old 06-06-2007   #1
tenedios
Question door light switch replacement source
I have a 1991 ZR1. All of a sudden the interior lights would not shut off with the doors closed. I discovered that slight pressure,approx.1/8"
on the outside of the right door would switch off the lights. I placed a wad of duct tape inside the door well opposite the switch and this solved the problem. I searched the registry and one post stated this was a common problem for the ZR1 and the remedy was to replace the door switch. First of all, I can not see how I can make the door close any tighter. Also I searched the net for replacement sites, such as Ecklers, and could not find a replacement. Do any members have another remedy or source for the door light switch? Thanks for your time and suggestions ! George
tenedios is offline   Reply With Quote
Old 06-06-2007   #2
DaveK
Default Re: door light switch replacement source
I have a similar problem and just ordered some from Corvette Central, p.no 594326
www.corvettecentral.com
Ecklers lists them as part no. 20196 but CC was closer for me and works with the Canadian customs...
Good luck.
Dave
1991 #1516 Black/Black
davidmkelly.com
"Speed is often confused with insight." - Johan Cruijff
Old 06-06-2007   #3
91King
91King's Avatar
Sounds like the plunger is sticking inside the switch unit. I had the same problem with both doors on mine. I pulled the plunger to the full out position and then applied a small amount of lubricant then worked the plunger in and out until it would return to the full out position on its own.
You will find a couple of photos on this subject in the "ZR-1 How to" section of the Registry. BTW you get to the "How to" section through the page on vehicle maintenance.
91 red/red #1813
EES 402
91King is offline   Reply With Quote
Old 06-06-2007   #4
DaveK
Wow! I managed to somehow entirely miss that! Thanks!
davidmkelly.com
Old 06-06-2007   #5
tenedios
Thank you . I did oil the center plunger and got it to stick out farther and activate the switch. thank you. YOU saved me some money in ordering a new one. George
