#231 |
#232 | |
Sorry Bob I missed this I will snap a pic for you today
#233 |
![]() http://www.orange-electronic.com/en/..._about_us.html http://www.amazon.com/Orange-Electro...pr_product_top
#234 |
![]() Join Date: Jan 2004
Daryl is correct, it's the Orange P409 and yes I can make more display screens.
#235 | |
Bob do you still need that pic? Sorry I missed your Bueller call. D
#236 |
The clear window in the display screen measures 2 1/8 by 1 3/8 in., I could have them alter that dimension a bit if need be. I can also have them add one or possibly two more warning indicators.
#237 |
No but thanks anyhow Daryl, three folks confirmed no bulb test on the low coolant, oil and ABS active. I also manually grounded the lights at the connector just to make sure my re-pinning was successful.
#238 |
Okay so here is a little vid with the new DIC unit, obviously the pressure sensors have not been installed in the tires yet.
#239 |
Just got the final edition of my heated seat control panels back, slapped in a little paint and then did a back light test. The lettering color is super close with the back lighting off but its a bit more yellow than the factory tint once the lights are on... not sure what else I can do here... it's not super noticeable from a distance but its there.
#240 |
Couple of shots of the DIC, the plug-in for the TPMS unit just slightly obscures the service ride control light in the upper right hand corner but that's not going to hurt anything.
![]() ![]() With the cover removed. Something odd is going on with the check engine and service abs bulbs. They both come on full bright as they should at initial key on... but then they stay on at a reduced brightness. You can see the service select ride at the far left on full bright (need to try to reset this), then the check engine light is at about half brightness, and the service ABS is just barely emitting a glow. All of these should be off. Any idea what could be causing this??? The bulbs are all LED's. I really perplexed, I don't see any obvious wiring issues. ![]()
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 Last edited by Locobob; 06-04-2014 at 01:47 AM. |
