Go Back   ZR-1 Net Registry Forums > Corvette > Corvette Audio/Electronics
Old 05-15-2014   #1
4CamJon
Default Bose help needed
I just bought a 91 ZR-1 and the Bose radio has no sound but the tuner works. When I got the car the battery was dead. Could the radio be coded? I don't have any manuals for the car and I can't remember if they say "Code" on the display or not.
What is an easy way to trouble shoot the system?
Thanks,
Jon
4CamJon is online now   Reply With Quote
Old 05-15-2014   #2
Default Re: Bose help needed
Thanks,
Jon
Speaker Amps may need replacement. Bose Speaker Amps
Old 05-27-2014   #3
4CamJon
So in your post on the amps it says 95-99 Maxima speaker amps. Does it matter which model Maxima that is or do they all have the Bose speakers? I see that it has to be a specific amp number or they don't work.
Thanks for your help!
Old 05-27-2014   #4
I did not know there was different 95-99 maximas
This is what you are looking for. You will need the white connector on a pigtail also.
You should be able to get these amps for $5-$7 at pull your parts wrecking yards.
Old 05-27-2014   #5
4CamJon
They had a GXE and a SE model. If it is with the base radio that will help me when I call the salvage yards to see if I can find some.
Thanks again.
Old 05-28-2014   #6
4CamJon
I just looked at a 98 Maxima and it had Panasonic rear speakers with the factory radio so I am confused. I will keep looking.
Old 05-28-2014   #7
I guess 95 Nissan Maxima only then.......as I think I got them from 95 Nissan Maximas as I recall.....
The 95' Nissan Maxima Speaker with Amps look like this.....
The 95' Nissan Maxima Amps are direct replacements for Bose Amps in the ZR-1.
The only issue is the little white connector on the Nissan Amps is much more usable than the original soldered connection (1990 ZR-1s) on Bose Amps. Pigtails for Nissan Amps are available.
95' Nissan Maxima Front Speakers..................................95' Nissan Maxima Rear Speakers
See Bose Speaker Amp Options TIPS
Old 06-01-2014   #8
95 LT5
95 LT5's Avatar
1996 Maxima also. Just picked up 4 today. Thanks for the help on the solutions page.
'95 ZR-1
RED/GRAY
#261
'95 ZR-1
BLK/BLK
#268
'89 6-Spd
FX-3,Z51
BLK/BLK
95 LT5 is offline   Reply With Quote
Old 06-01-2014   #9
Great Information....I am assuming those amps were SIGMA 975s Front and Rear?
thanks
Old 06-01-2014   #10
4CamJon
I went and looked in a 95 Maxima and it also had Panasonic rear speakers with the factory radio. Is there an optional Bose stereo package for the Maxima's that is some models?
