![]() Join Date: Feb 2014
Picked up the car yesterday after having the stock 3.45 changed to 4.10 Danas. It appears that I am a victim of my own inflated expectations. After hearing the accolades and reading on this forum a post from a guy who literally said he practically had to "relearn to drive the car" after getting 4.10s, I guess I expected the car to take flight or something. Hmmm, not quite. Yeah, I can tell a small difference but I'd be willing to bet the car is no quicker to a stopwatch, which is kind of a bitter pill to swallow when I just spent $1500 to get "18% more torque to the rear wheels at all engine RPM", according to Marc.
Driving the 2 ratios back to back, I don't feel any 18% torque difference. Not even close. And yes, I did confirm that the stock 3.45s came out of the car. I can say this for sure: if your car is stock or near stock and you're thinking about new gears, DO NOT do anything less than 4.10s. You'd be flushing money down the toilet. Just my 2 cents. ![]() |
![]() Join Date: Jan 2004
I'm of the opinion that gears shouldn't be looked at as a power adder but rather as a tuning tool to get what you want out of the car. You really only get the extra torque in first gear (provided you have enough tire to hook it up), after that you are just changing shift points.
![]() Join Date: Feb 2011
Obviously gears don't change the torque at the flywheel or affect the power of the engine at all, but what it does do is get you to the sweet spot a little sooner which would be more obvious during acceleration timing, quarter mile runs etc.
6th gear may actually be useful uphill no as well. |
#4 | |
#5 | |
Would of been nice to see before/after dyno sheets
I still think you made a good move and only will compliment the rest of your future mods You should now be at aprox 2200RPM @ 75MPH |
![]() Join Date: Aug 2008
Killshot you will feel more of a difference installing a Fidanza flywheel than gears. A light weight flywheel doesn't ad hp either but less rotating mass on the crank is very noticeable. RPM's rise very quickly.
![]() Join Date: Dec 2012
With stock 3:45' I can spin the tires at will in first gear/ I cannot see how 4:10's would benefit me, it would only light up 2nd gear.
#9 | ||
Now the reason you might not "feel it" is because you have altered your shift points when comparing before and after shift points at specific vehicle speeds. You now have a useful 4th, 5th and 6th gear. When before you could top out the quarter mile in 3rd gear. Oh...and I can spin my tires in 1st, 2nd, and 3rd gears ![]() See Tech Info - LT5 Horsepower and Torque Calculations I happen to like stock rear end ratios as I can get that 28mpg cruising in sixth at 70 mph ![]() Quote:
Hi rhipsher ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 05-18-2014 at 08:24 AM. |
#10 | |
