Old 04-27-2014   #11
JimZRyd
JimZRyd's Avatar
Default Re: Brainstorming future brake upgrade
My original post was just asking for some feed back on a few replacement rotors...not a "who's got the biggest" pressure generating system. My Z's not a track car. If it was then I'd be interested in Learning more about Bobs system. So what about rotors guys? Anybody got anything else to add?
Jim Zorgias
1994 ZR-1 Admiral Blue/Black #245
1996 Callaway Supernatural 450
1990 Callaway Supernatural 490 / CR-1 #7
JimZRyd is offline   Reply With Quote
Old 04-27-2014   #12
USAZR1
USAZR1's Avatar
http://forums.corvetteforum.com/c4-t...endations.html
Clint & Sherry
1994 ZR-1 White/Red #152 (sold)
1991 ZR-1 Callaway Aerobody #1332 (sold)
1990 ZR-1 Red/Red #952 (sold)
2002 Z06 Torch Red/Mod Red widebody
USAZR1 is offline   Reply With Quote
Old 04-28-2014   #13
batchman
What USA said.
Be cautious of brake upgrades. The stock J55 setup is a pretty good compromise between stopping and living with the system, although I would prefer a larger master cylinder bore and more rear bias in our ZR-1s. It's pretty easy to wind up with expensive to maintain components that are waaaay too noisy and dusty for street use. A lot of the "upgrade" pads are not designed to work when cold - which is how most street brakes spend their time.
I have found that the Carbotech AX6 is a great "cold" brake pad but even that needs me to drag the brake pedal a bit before first real need. It is wildly dusty and a little bit noisy, but the dust is very benign - doesn't eat your paint (like many do).
And when it comes to rotors, the drilled ones just give you more places for cracks to start. If you must have holes look for cast-in ones, which I don't think you'll actually find.
HTH,
- Jeff
[I]91 ZR-1 #1840, autocrossing in SCCA BSP. FIC S/S's
DRM chip/Watson/Borla/lid/LW batt&headlights,
springs, shocks, pads & lines, quick rack & Turn One,
camber brace, 32/22mm sways, A/C halfway deleted
17x11 & 12 CCW's, 315 & 335 Hoosier A6s
[/I]
Old 04-28-2014   #14
pantera1683
I have a pair of gently used 13 inch front Baer Eradispeeds available if interested. Picked these up as a spare with only 5K miles on em. GC
How much and what color are they?
Old 04-29-2014   #15
Hib Halverson
Unless you are racing or maybe you need to have calipers which are bigger and more colorful to give your car a badder look, the stock brakes on a ZR-1 are pretty darn good.
If you need an upgrade but are looking for a bolt-on, high-bang-for-the-buck modification, I'd try a slightly more aggressive brake pad, one of those aftermarket front air dams with brake ducts along with a fluid flush.
Old 04-29-2014   #16
I just dressed up my stock calipers until I find a set of 96 GS calipers
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 04-29-2014   #17
icarus-54
icarus-54's Avatar
nice
1990 Zr-1 #361
1991 GMC Syclone (built)
1993 GMC Typhoon (stock)
1993 GMC Typhoon (street)
1992 GMC Sonoma GT
1928 Model A pick up
icarus-54 is offline   Reply With Quote
