Old 04-13-2014   #12
Default Re: Power Antenna removal?
Do you have to remove the top nut by the mast? This is the one under the grommet where the antenna protrudes through the body or is that just the mast keeper nut.
Think I might have replace the assembly depends g if I find any bad connections
You do not have to remove the nut under the rubber grommet. This nut holds the mast onto the antenna housing. Once you remove brackets that holds the antenna to the metal bracket for the rear bumper, antenna drops down from the grommet.
