03-17-2014 | #11 | |
Re: Spare tire and carrier
C6Z not C5. The C5 is not an issue, but the C6Z calipers are huge and require a flat faced 18" wheel for clearance. IOW, the Shelby's don't work without modification as an example.
03-17-2014 | #12 | |
See Item # 14 ZR-1 (90' and 91') Wilwood Rotors and C4 to C5-Z06 Conversion I will also check the spare wheel on the C5 Z06 brake conversion (Front). I assume 90' and 91' spare wheels are identical?
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 03-17-2014 at 11:28 PM. |
03-17-2014 | #13 |
I'll check the spare clearance on the rear Z06 calipers and report back.
