I need a new one and I see several on EBay. Delphi for one, for $320 including gasket and strainer. My GM dealer wants $600 plus for one. Ecklers list a separate one for the ZR1. Whats up? Tks
#2 | |
Here is the link: http://www.zr1.net/forum/showthread....ght=fuel+pumps Last edited by pantera1683; 02-26-2014 at 12:24 PM. Reason: Added link |
![]() Join Date: Mar 2008
![]() Join Date: Nov 2011
If Jerry's got it, I'll second that.
![]() Join Date: Jan 2009
The ones on Rockauto.com are fine for $20 ea.
PERFORMANCE ELECTRIC Part # P240KC They fit with no cutting the holder. Just replace both while in there and do NOT ever run the pump in open air. It damages them. Don't ask how I know. For more info see: http://www.zr1netregistry.com/Inform...ent-Steps.aspx and http://www.zr1netregistry.com/Inform...placement.aspx
Scott ![]() Vett owner since 1979._It's about the car and the people Last edited by scottfab; 02-26-2014 at 05:35 PM. |
Look for BB 454 Suburban pumps. They're the same thing. I would try the Bosch units if I needed replacements.
![]() Join Date: Nov 2007
I and several others had issues with the Airtech units, listed at AutoZone as the replacement for the pump. FYI.
As an aside, at 40k miles I replaced my fuel filter (located on the frame, behind the right front wheel) the same time I replaced my fuel pumps. I was shocked at the amount of crud that was in there!. ![]() |
Great point! That and the "socks" on the pumps. Sometimes they are plugged to the point where the pump is sucking up the socks impeding the flow of fuel. |
I agree. The strainers should be swapped out too. Most pumps come with one.
Scott ![]() Vett owner since 1979._It's about the car and the people Last edited by scottfab; 02-27-2014 at 08:45 AM. |
#10 | |
![]() Join Date: Jul 2007
