02-04-2014 | #11 | |
Re: Headers install tips? Cliff???
I will be using stage 8 bolts and copper header gaskets as I do not want to do this job twice!
1993 ZR-1 #211 Yellow On Beige Beast #2 1992 ZR-1 #427 Black On Black *Sold* 1985 L98 Blue On Blue *Sold* Last edited by Karl; 02-04-2014 at 04:51 PM. |
02-04-2014 | #12 |
Did you go with the OBX headers,Schrade?
Clint & Sherry 1994 ZR-1 White/Red #152 (sold) 1991 ZR-1 Callaway Aerobody #1332 (sold) 1990 ZR-1 Red/Red #952 (sold) 2002 Z06 Torch Red/Mod Red widebody |
02-04-2014 | #13 |
02-04-2014 | #14 |
Yes I did there Clint - I thought for some reason that HAB055 OBX was discontinued, but they're showing up in a few places on the web (not on OBX' site search tho').
That was my preference, since that's what Jeff [Shrek] had on his wife's Z, matched up with the Power Effects pipes that I bought from him last week... What is 'Stage 8' hardware? Same as Grade 8? And what kind of anti-lock thread compound? Copper? Aluminum? Or Teflon / PTFE??? And will penetrating oil get in hot heads better than if it's cold to start with? Are snappics worth posting here? Anyone interested?
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] Last edited by Schrade; 02-04-2014 at 06:50 PM. |
02-04-2014 | #15 |
Stage 8 bolts have a splined head, a locking tab, and a clip that holds the locking tab in place. Gaurenteed not to loosen, if you can get the clip in.
02-04-2014 | #16 | |
No problems and well worth the piece of mind.
1993 ZR-1 #211 Yellow On Beige Beast #2 1992 ZR-1 #427 Black On Black *Sold* 1985 L98 Blue On Blue *Sold* |
02-04-2014 | #17 | |
Headers install
With the Stage 8 I hand tighten moderately with Anti-seize on the Stage 8 Header Bolts since they are locked once installed. You do NOT need a torque wrench on the Stage 8 bolts with locks when installing. I do use a bit of Anti-seize on the Stage 8 Header Bolts. If you like you can remove the engine and install the Headers and then reinstall the Engine With Headers Installed Installing Engine In ZR1
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-04-2014 at 07:30 PM. |
02-05-2014 | #18 | |
Re: Headers install
02-05-2014 | #19 | |
Re: Headers install
And make sure those Ratcheting Box Wrenches are Flex Head I use the wobble extensions on almost everything. The wobble extensions are in first picture and flex ratchet combination wrenches in second picture. Exhaust System Replace with Headers
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-05-2014 at 12:16 PM. |
02-05-2014 | #20 |
It wasn't the pointy lock tab that wouldn't fit, it was the jesus clip that held the pointy lock tab.
