Old 01-13-2014   #11
Default Re: Engine Smoke
The header stud leak can be deceiving it can run down the header....
Yep
Old 01-13-2014   #12
DarkAngel
DarkAngel's Avatar
i have the original emblems but the paint is gone on some parts
DarkAngel is offline   Reply With Quote
Old 01-14-2014   #13
Don't loose the emblems. Might be some NCRS car that needs some original$.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 01-29-2014   #14
DarkAngel
DarkAngel's Avatar
i've checked Header bolt and cam-cover and it seems it doesn't come from there
everything is well tighten
you mention sensor cam but i have no idea where the sensor cam is?
is it easily reachable ?
Old 01-29-2014   #15
Cam sensor is on the drivers side of the engine. On the side of the motor between the 3rd and 4th plenum runner if you follow from the top down to the side of the motor. It's protected by a little metal heat shield and is retained with one bolt. It also has a o ring
