#11 | |
![]() Join Date: Jul 2010
peace Paul ZR-1 Net Registry Member #1494 |
#12 |
![]() Join Date: Oct 2004
#13 |
![]() Join Date: Dec 2012
Watching the videos it seems to me that the speed each gear runs up to 7-8000 rpms is faster than a 3:45 rear end. I relate since I also have a 2008 TBSS with LS2 that came from GM Performance group with a 4:10 rear end so I have a direct comparison of two over 400 hp engines and a 3:45 and 4:10 rear end. I'd guess you have a 4:10 rear end in the Z from watching the videos of the one that gets to 100 mph in third gear. I get to 125 mph in third gear in my stock 1991 Z with 3:45 rear end. Speed to get through each gear seems more like a 4:10. Check it.
Lance Pearson Chester, Virginia [COLOR=red][I]'76 L48 four speed[/I][/COLOR] [COLOR=red][I]'91 ZR-1 #00682[/I][/COLOR] Net Registry #1461 |
#14 | |
#15 |
![]() ![]() Join Date: Nov 2007
My money is on the voltage divider on the cluster board. The divider that biases the op amp for the tach is printed on a ceramic substrate. It is exposed to the air, and over time deteriorates.
By comparing the analog tach reading to the the digital rpm value on a scanner connected to the ALDL, it is easy to determine if the tach is reading correctly. It is my understanding that over time and exposure to air, the resistance value changes, resulting in the analog tach reading to creap up. (Mine was reading well off the scale when it was at only 7000 rpm.) Check that first. If tach calibration is the issue, "there is an app for that!" ![]() ![]() ![]() P.
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 12-10-2013 at 04:17 PM. |
#16 | |
The ALDL datastream has a tach ceiling of 6300rpm which is the limit of the L98 datastream. Granted the rpms change rapidly at that point, but if you want to check tach error v the datastream, do it at a point below 6300rpm. There is raw data for rpms which can be output with a change in the ALDL datastream, but you will need to convert that to rpm.
#17 | |
I would guess that likely 95% of the '90 cars if checked likely have an issue OR they've been corrected. How many are aware? Who knows. |
#18 |
![]() Join Date: Feb 2011
stock rev limiter is 7100 rpm. I would suggest revving it until 7100 rpm and then the ecm will cut the ignition. Compare tach reading to known actual rev limit of 7100 rpm.
#19 |
#20 |
Thank you everyone for all your quick answers
![]() for tach limiter, i have a chip so i don't know if i still have the rev limit at 7100 furthermore, i don't really want to hit the rev limit :-S |
