The drivers side headlamp door does not close completely. I have adjusted the knob on top of the motor and it takes out some of the play temporarily but it comes back loose.
Is there another adjustment? Is something worn and in need of replacing? Has anybody else experienced this problem? |
More than likely its the 3 bushings inside the gear. They`ll be crumbled and almost turned into powder. They`re 1/2 inch in diameter and length. Take the whole headlight assembly out and put it in a good uncluttered work area. You can do it but its tricky. The passenger side won`t take half as much time with the experience you`ll have. Be sure and get 6 bushings as i`ve replaced about 5 sets and always found both sets to be in about the same contition.
I noticed some yellow granular residue under the motor on the passenger side but that one is working OK. I guess from your post it wont be for long. Where can I get the replacement bushings? Ecklers? I wouldn't expect GM to have anything for a 20+ year old car.
Ecklers, Madvet etc has them. Suggest buying enough for both sides
Step by step http://home.comcast.net/~zrjuan/headlight.html
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 11-25-2013 at 04:03 PM. |
![]() Join Date: Sep 2012
http://www.youtube.com/watch?v=sPj1kJm4AnU
I watched this video, basic tools. Did mine in under 90 minutes including removing and replacing the assembly in the car. I am not mechanically inclined. |
![]() Join Date: Nov 2011
"Pumpman" where does the handle come from? My family has been in the pump business for three generations. Pumps as in water pumps for your well.
#7 | |
I just added some pics of this operation. May be helpful to you. http://www.zr1.net/forum/showthread.php?t=21643
Replaced the bushings in both sides over the weekend. Everything went smoothly. Took maybe 35 minutes each side. Headlights work perfectly now. The video was a great help.
#10 |
Good to hear! Drive it like you stole it.
