#251 |
![]() Join Date: Feb 2011
then it vents the actuator diaphragms to the atmosphere speeding up their closing. You should be able to vacuum charge the little black can reservoir at that point. You may have to apply 12v to get the vacuum to pass to the secondaries- I'm away from my FSM's at the moment, but that is the testing path i would take.
#252 |
![]() Join Date: Nov 2007
#253 | |
Where the link here Cliff? |
#254 |
I just tie-wrapped mine open. Later on I took the throttle plates out and left the shafts in. Need to modify the cal so the ECM thinks the secondaries are OK and won't throw a code. I ran like that until I put on ported heads and cam. With just top end done, it pulled 400 at the wheels w headers.
#255 |
Completely reversible if you tie them open. Just the cost of gaskets and the chip and the tune. I doubt you would ever switch back!
#256 |
Is there a vac schematic that shows where to cap off vac lines? To retain Cruise and EVAP functions?
How do you know that the tied sec linkage is holding the sec ports' butterflies perfectly vertical? Or are they vertical when 'pegged'? |
#257 | ||
I retained the secondary system on my 90' and eliminated secondary on 91' ![]() I just wanted to experience the power key on my 90' and not have anyone accuse me of not being able to get a secondary system functioning ![]() What you should do is eliminate TB coolant....naw.....I promised GC I would not mention that...so forget I said that ![]() Quote:
You can tie wrap or remove secondary plates or remove shafts completely. With your mechanical talents, anything and everything is reversible ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 11-17-2013 at 12:20 PM. |
#258 |
#259 |
#260 |
All the HVAC, cruise, etc gets it's vacuum from the starboard-side plenum nipple between #4 and # 6.
On mine I left the port side vacuum connector (the one that serves the SPTs) and a short piece of the hose tucked under the plenum. But, the hose is plugged, giving it an "un-altered" appearance. Same goes for the TB bypass. The IH is plugged, but I left the hoses "as tho" everything were stock. (That way Scottfab wouldn't have a cow if ever he saw a photo of my motor ( ![]() ![]() Hats off to you. You may not have all the answers (most of us don't), but you haven't let that deter you from forging ahead anyway. Serendipity is one hell of a teacher!! In the end, you'll know more about the top end (at least) than more than half of the ZR-1 drivers do, I'd bet! Good on you!! ![]() Last edited by Paul Workman; 11-17-2013 at 03:47 PM. Reason: tpyo |
