Old 11-13-2013   #1
Y-me
Default How to remove timing chain?
I've done this before but have forgotten, how do you pull the timing chain and gear off this thing?
Y-me is offline   Reply With Quote
Old 11-13-2013   #2
Y-me
Default Re: How to remove timing chain?
Remove camshaft chain tensioners. Set crankshaft at 51 deg BTDC. Remove front and rear camshaft retainers (two each camshaft) including thrust washer on within front camshaft retainer. Tip camshafts up from rear and slide timing chains off camshaft sprockets.
I mean the main one that looks like a regular 350 timing chain.
Old 11-13-2013   #3
Y-me
There are three bolts in the Timing Chain Idler Sprocket...maybe this will give you a clue
LT5 Timing Chains and Sprockets
I think the primary crankshaft sprocket for the Timing Chains will slide off the crankshaft (there is a key in place to keep it locked to the crankshaft rotation).
Oh....remove the main timing chain tensioner to give you some slack in the Main Timing Chain.
Took the three bolts off already and the tensioner, I already did all that before asking. but thanks for being condescending.
Old 11-13-2013   #4
Schrade
I wouldn't say that's condescending. Cliff is very helpful.
Old 11-13-2013   #5
ScottZ95ZR1
ScottZ95ZR1's Avatar
Perhaps it was Cliff's post including "maybe this will give you a clue" that seemed condescending? In Dan's defense I'd have taken that comment as less than constructive as well.
ScottZ95ZR1 is offline   Reply With Quote
Old 11-13-2013   #6
tccrab
tccrab's Avatar
Cliff is an extremely nice, intelligent, kind, decent and witty kind of guy.
I can personally guarantee he meant no offense.
'Crabs
Old 11-14-2013   #7
Pete
Pete's Avatar
If you took the 3 screws off the main cluster gears have a center dowel it's probably stuck you might need to work it a bit just make sure your clear of guides etc work it out it will come off.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
