Old 11-10-2013   #211
efnfast
Default Re: TOP END REFINISHING
Nice right up Schrade. Much braver soul than I tearing into it like this.
Old 11-10-2013   #212
efnfast
There is a fine line between bravery and stupidity. So far, so good on your part.
Old 11-10-2013   #213
Franke
Maybe fishing with a magnet could help?
Old 11-11-2013   #214
But now, a setback.
The socket popped off of the socket driver, while tightening the CC cross-over pipe clamp, between the fuel rail inlet / return lines. First time, it hit the floor. SECOND time, it didn't. I cannot find it anywhere. It was BELOW the IH port, so that's a good thing...................
Had to laugh! But I lost a 1/4" drive ratchet handle...exactly doing what you were doing. It NEVER hit the floor, and I spent a couple hours looking for the damn thing and never found it! SO! If you find your socket, see if my ratchet handle is there too!
Old 11-11-2013   #215
Schrade
FP test; I blew something at #8, or at rail cross-over, P side. I heard the air right away, and let off the jumper, then saw some drops - not enough to see exactly where, but enough to see tomorrow's starting point...
Inside work now; carve up C4 / ZR1 decal for TB extension...
And bury under some poly...
Old 11-12-2013   #216
mike100
You should do a separate post on how to make those DIY clear decals.
Old 11-12-2013   #217
Schrade
Add to the list of How-NOT-To's
After re-assembly of the P side rail LAST night, I did the FP test, and failed. I heard the air blowing, and let off the FP jumper.
Today, I found out why
When I sank the rail, I sheared off part of the O ring, just as clean and neat... That piece is probably under the starter. Guess where it's gonna' stay
When I broke it down, to find the wayward socket, the gasoline that drained from the INJ port, out of the rail, rinsed off the oil, and the port dried out. It HAS to be clean, AND OILED, as Jerry was saying. It was clean alright...
I had O's from LT1 top end re-work, and replaced it. WITH oil.
FP test result - tested with primary FP only, was identical to earlier FP test. The secondary FP, when plugged in, forced the air out (((not done yet; it was low 30's wind chill. If I'd had a wooden stick in my ace, I coulda' been a popsicle )))
Old 11-12-2013   #218
Franke
Schrade, make sure that new O ring is Viton for ethanol fuel. In the pic it looks like a different color from the others and I was wondering if is was Viton or BUNA.
Old 11-13-2013   #219
Schrade
Still working dry-fit to anticipate problems...
Between which 2 injectors does this vacuum hose go, that comes into the plenum P side center...
I have it where I found it, but it ain't 'sittin' exactly happy where it is...
Help? Again???
Old 11-13-2013   #220
Franke
Schrade, looks about right ... not sure why its being difficult. Perhaps its stuck under the plenum. Check post # 37 to see if any help.
