![]() Join Date: Feb 2013
What is the best way to get the tensioner out of the car when the bolt has been removed ?
92 #214 |
![]() Join Date: Feb 2011
I remember having trouble with it. Somebody correct me, but I think you can finagle it out the bottom if you do it just right.
![]() Join Date: Jul 2013
Came out through the top for me just fine. You might have to push the crossover pipe a bit, but it comes out the top easily. About a 3-minute job. Now torquing that bolt when reinstalling is another problem entirely. I could not get a torque wrench down there no matter what I did, and I had completely removed the coolant pipe and hoses. So I got creative with a wrench and some math.
#4 | |
Ah then maybe it was the top- I know that it will NOT come out from both directions. |
Thanks for your help. Even with the TB horn removed, it was not possible to get the tensioner out of my 92 by the top. The coolant pipe is too close from engine front. What was possible with the horn removed was to get out the pulley and replace it. The tensioner it self was OK.
#6 | |
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-14-2013 at 11:15 AM. |
