Old 10-24-2013   #31
Default Re: Brakes That Will Stop A Freight Train
What about with C5/C6 front Baer eradispeeds? Anybody done that setup yet? GC
Old 10-24-2013   #32
bamawrx
Has anyone checked to see if 90 or 91 wheel would clear this setup?
bamawrx is offline   Reply With Quote
Old 10-24-2013   #33
Guaranteed not to fit 1990 or 1991 wheels without spacers
You would need 1994/1995 A-molds to run this brake setup. (Without spacers)
Old 10-24-2013   #34
David............I would say the A-Molds I used on both a 90' and 91' are absolute minimum wheel geometry to fit this C5 Z06 Brake Conversion. I measured the key geometry elements which should make it possible for anyone to check their own wheels with the same measurements.
Dimensions of wheel that BARELY fits over this C5 Z06 Brake Conversion Using Wilwood Rotors
Old 10-30-2013   #35
Default LED Tail Lights are ON
LED Tail Lights are ON.........just making sure someone behind can see me when I apply the BRAKES
Old 10-30-2013   #36
Default Re: LED Tail Lights are ON
Now have Jeff make you the -=JEFF=- LED CHMSL !!!!
By the way SCHWEET
Also Cliff its gotta be getting cold..... Any OWL signs .......
Old 10-30-2013   #37
Now have Jeff make you the -=JEFF=- the LED CHMSL !!!!
By the way SCHWEET
The Owls live in one of my sheds that has open doors so they can fly in and out. They keep all the mice in check
