Does anybody know what the 20-45 in the AC DELCO rear bearing hub assembly means? Its not a part number so?
Also need a part number for that plastic washer thingy and rear axle seal? WV ?
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 10-24-2013 at 10:45 AM. |
#2 | |
![]() Join Date: Oct 2004
The axle seals would require the removal of the differential from the car and if you were going to that effort it might be time to do all three seals. Doing all three seals with an OE differential build would only require the seals and I'd do a new pinion nut. If it's an after-market build you need a new crush-collar also. Some say NOT - I think so! Maybe consider the bearings for the short axles also if you're doing the axle seals. If you're thinking there's a seal at the hub there isn't, there's also NOT a plastic "thingy" but if you're referring the spindle washer the GM # is 14076924. |
![]() Join Date: Feb 2011
The teflon coated axle washers? They do recommend replacing those, but I never have. The source of noise on both of my C4's has been dry, rusty splines in the hub.
GM #14076924 I think. Last edited by mike100; 10-24-2013 at 11:58 AM. |
#4 | |
Use it for assembling anything with a slip/splined fit, pinion flange, transmission slip-yoke and the hub/bearings I mentioned. GM uses it for intermediate steering shaft "clunk" - drive-line "clunk". If you do your own spindle bearings for mowing blades or have a propeller shaft drive of any type it's good stuff to have around. |
Thanks WV found a NOS front and rear hub from a forum member.
#6 | |
