while cleaning and setting up for w pump install I noticed seapage around top of threaded hose with the disconnect on it so I grabbed it and it became disconnected (broke) in my hand,if I cant get this out anyone know my options if theye don't make them anymore???????
#2 | |
Jerry says The original part was cast from pot metal which corroded and was easily broken off in the thermostat housing. If you are talking this ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 10-20-2013 at 07:59 PM. |
![]() Join Date: Oct 2004
It would be very wise if "all" owners actually checked that fitting when doing maintenance or if you don't remember ever checking, do it! The early production fitting was used in most GM's of the time and the material actually swelled and became fatigued. It wasn't uncommon to have these fail on any GM that used them.
I don't know how you would remove the threaded aspect of the nipple in the ZR-1 short of removing the t-stat housing and doing it on the bench. I've never needed to so. Jerry of course has them but if you were in dire need it should be "on the shelf" at most GM dealers, ACD jobbers and most auto parts stores. The service part is certainly the more desired product! If you can't get a 1 1/16 (27mm) end wrench on it you need to be concerned. The OE is only similar to Cliff's image but Cliff's is what the later "service part" would appear as. Last edited by WVZR-1; 10-20-2013 at 07:10 PM. |
THATS IT!!!!!! very brittle however I have everything apart may as well pull the housing out and see if I can get the leftover out,Im sure by its weakness it would have let go.
Can you get some snappics posted, to see what you've got going on there?
