Old 10-18-2013   #31
HAWAIIZR-1's Avatar
Default Re: Searching for a Fuel Line Clip
Where did you find that?
Where else, I googled it.......I thought you might like that.
http://www.etsy.com/listing/16043993...?ref=related-1
Speaking of google, I saw that their stock hit $1000 a share.......man I wish I invested in their stocks years ago as I would have ordered a C7 Stingray as my daily driver if so.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 10-18-2013   #32
carter200
carter200's Avatar
I am standing by my mail box tomorrow...just in case.....I will post photos here of the Carter Fuel Line Clip installed
Cliff,
I just finished painting your engraving. You might want to take a break on the PO Box vigil for a few more days. I'll be mailing out to you on Monday.
Jim,
Thanks for the kind words. Pics from both of you would be great! Again thanks, Carter
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 10-20-2013   #33
1991ZR1
I received the fuel line clip today. I decided to try installation right away. Things did not go well. Nothing to do with the clip though. When I tried to take the nut off, the stud came out instead. I'm thinking of using epoxy when screwing it back in. When I took the old broken clip off, I dropped it into the engine compartment. It made a sound like it hit the exhaust shielding. It did not fall to the ground and I can't see where it went. I'm afraid it may be inside the shielding and if I leave it there it will melt when things heat up. One day I'm going to jack the car up and try to find the clip from under the car.
1991ZR1 is offline   Reply With Quote
Old 10-20-2013   #34
HAWAIIZR-1's Avatar
Craig did this...it is all his fault.....
Hey Cliff,
Did you order the vintage button from the link? They only have 1 left.
Maybe Carter can make you some billet center caps for your wheels with this design?
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 10-20-2013   #35
carter200
carter200's Avatar
I just noticed that....yes....I got it......[/B]
That is sooooo funny......thanks there Craig
The stud coming out is not unusual.....I think I would just screw the stud back in tight but not so tight you strip the threads in that box material.
You can always epoxy the stud if you strip the threads or if you want to make the stud permanent later. If I am not mistaken, Carter machined a recess for the stud collar so the fuel line clip is snugged up tight against the box and not just snugged up tight on the collar of the stud.
That little clip melting somewhere is really not a big deal....just let it melt and when you remove the exhaust adding headers you will find the little crisp piece of what is left. It should not hurt anything where it dropped. I have found all sorts of dropped items including injectors down among the suspension components so guys/gals dropping things and leaving them is not unusual either
Yes, I machined an inside step to clear the stud flange and to allow the billet fuel line bracket to rest flush on the boss. When I installed my billet fuel line bracket the stud was loose on mine, too.
I just retightened it and installed the bracket with no issues. Be sure to orient the two halves of the billet fuel line bracket by mating the two sides with the RED mark on each half.
Thanks again, Carter
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 10-21-2013   #36
carter200
carter200's Avatar
Hey Cliff,
Yes, I CAN do a set of center caps like the
Remember it's only money.....
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 10-25-2013   #37
carter200
carter200's Avatar
Carter Fuel Line Bracket Installed.
Very nice (I mean extremely nice) Carter
Bracket Top and Bottom................................................Bracket Center
91 Octane on one end of Bracket and 87 Octane on other end of Bracket.
91 Octane.................................................. .................87 Octane
Cliff,
You should be able to get the two halves to come together to make the 87 look better. Let me know if any issues, Carter
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 10-25-2013   #38
carter200
carter200's Avatar
I was sooooo excited I did not clamp it tight.....
Can you post another pic with it clamped tight? I would like it as the other makes my work look not so good..........You could even replace the untightened pic with the "tightened" pic. Thanks, Cliff, I appreciate it, Carter
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 10-26-2013   #39
JimZRyd
JimZRyd's Avatar
Here's my bracket that I got from Carter last week. The quality of his work is extremely nice! It was more difficult than I expected to line up the fuel lines to where they would sit in the bracket correctly but once in place they look fantastic! Here goes a couple of pics...
Jim Zorgias
1994 ZR-1 Admiral Blue/Black #245
1996 Callaway Supernatural 450
1990 Callaway Supernatural 490 / CR-1 #7
JimZRyd is offline   Reply With Quote
Old 01-27-2014   #40
HAWAIIZR-1's Avatar
Carter,
Thanks again! I finally got around to installing the clamp/bracket today. It did not work like the photos in the post above, but I was able to get the clamps to close flush after pulling the entire end part past so that the bracket is holding just the steel braided part line. No matter what I did (red marks matching and all, even flipped around thinking one opening was larger) it would not clamp flush.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
